  • Replies 198
Posted Images
hmm her skin is a little pink now that I can see it on my work PC.. but yeah, i'd take the white glow out of it is what I was getting at.
on my screen that looks really dark :(
I guess this is the problem with digital photography.. Pictures always look different on various screens.
That's what I'm worried about - colour calibration tools for monitors aren't exactly cheap if you only want to do this as a hobby!
Just make it look good on your screen mate :worship:
(thats what I do!)
(although seem to have a recent issue where my home and work PCs are totally different :worship:)
Spyder 3 colour calibration is probably the best colour calibration tool but you definitely pay for it! $300 for the basic kit and then $400'ish or something for the pro kit... Worth it, if your making money from photography, but for the hobbyist/amateur, it's so not worth it lol.
I think macbook (pro's??) have there own kind of inbuilt colour calibration tool?
im going to start editing photos on my TV I think. See how they turn out.
I have 3 monitors connected to my pc at work and a picture looks different on each 1 lol
At the moment i edit on my 40" Full HD TV, i don't like it! Yes, its awesome to have such a uber huge screen, but the colours are a bit off and there not as easy to calibrate as a normal Monitor, but i still enjoy it lol.
Yes, same with me, i got 2 screens and each one is different lol.
I'm using a 40" Full HD TV as my monitor for my main computer, but most of my photos are stored on my laptop, and what little post-processing I've done on that (I'm still learning to use Photoshop) shows up completely differently on the TV.
Group buy on the calibration tool? lol
Ian - Nice pool table.. i mean bike... heheh i see the sticker :)
But nice lighting tho :( Just wish the handle bar up top wasn't cut off. However i must say thats a sexy bike!!
Kerr34 - umbrellas (those old Chinese ones) , those big colourful lollipops, balloons, etc etc.
A pic from yesterday:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
