  • Replies 328
Guys Just a warning I live in newcastle & work for exhaust company. Now Singleton Has a badass cop. Be very wary of this cop as he has a very bad rep For Caning import drivers with loud exhausts bov & loud intakes & front mounts. He will think Xmas has come early if he sees around 20 or so imports in singo. Hes a total wanker guys. He will even book you if your washer bottle isnt full. My suggestion is totally to avoid singo guys dont mean to put damper on things but just looking out for fellow nissan drivers. Suggestion Morpeth is a good place as it has 2 great pubs good food & even has shops for the girls.
Just a thought have a good one anyways guys
aww yeh... good ol mr smithe.. hes a top notch bloke.. he will sit on the edge of a fog patch and wait for you to come out with your fog lights on and book yo ass.. hes a great fella.
on a sunday morpeth is chocka block... people everywhere doing nothing particular.
hinton pub.. just after morpeth is a top pub.. with lots of room for parking.. do not go out to Paterson for a hamburger.... they used to be fantastic... but the old quantity over quality thing has taken over and its gone downhill.
there is a nice place in East Maitland called Anoushka's... it is a regular of mine and they make really good home cooked food.. big hearty meals and always fantastic... reasonable pricing too. but if you want to go there id have to book us in advance and dont you dare not come if youve booked.. FEAR THE WRATH OF JAN!!
What we need is a decoy hoon, like the guys from dukes of hazard. They can lead inspector smithe out into the bush for a couple of hours whilst the SAU cruise can travel in peace.
Id love to come, sounds like a good day. Ill be comming by myself and wont know anyone so be friendly and say hi :P
this is a great chance to get to meet everyone. i went on this last year for the first time and only knew a couple of peopl. but everyone is so friendly that you just fit into the group and before you know it you willl feel like you have known everyone for years.
i may be able to supply this "decoy hoon" i know a few guys i could send in first and take the heat off us.
but i think if everyone is behaves themself and has road worthy cars then this wont be a problem to avoid the cops. we just need to set a good example and not act like a bunch of tools.
easier said than done sometimes but its just common sence to behave.
I think our fully caged race car with straight thru zorst should be able to fill the role. while he gets his head around "rally rego" cars not having to meet ADRs everyone else can sneak past :whistling:
you don't want to hurt the poor officer, he may need some kind of therapy after thinking about such complex concepts!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
