I have two sets of AVS rims, both the same sizes.
One set of gold AVS Model 6 wheels (latest style), and a set of silver Model 5 wheels (older style).
Im looking at selling one set now, and leaving the other set on the car for when i sell the car next year. So wanting to know what rim has the broadest appeal so that i can leave them on the car for when i sell it.
Thoughts ppl? I dont have a digi cam so these photos courtesy of other ppl are the best i can do.
Gold Model 6
Silver Model 5
https://www.sau.com.au/forums/topic/28740-which-wheels/
I like the silver ones better myself.  I think they give it a classier look whereas the gold ones look more like you're out to do some bruising.
Just my humble opinion.
Actually, I prefer the gold ones, but wouldn't you get more selling them seperately then with the car?
https://www.sau.com.au/forums/topic/28740-which-wheels/#findComment-593212
Hey Roy,
Keep your model6's cause they're the same as mine! Look much better than the 5's. Looking at the pic they look like 17's? If you were to sell them seperately you'd get alot more for them. I bought mine 2nd hand and they were NOT cheap!
Also, whats the width of your goldies?
P.S: Sorry for bothering you about the intercooler last fortnight, i got it all sorted ;)
https://www.sau.com.au/forums/topic/28740-which-wheels/#findComment-593223
Fronts are 17 x7, rears 17 x 8. They are a good fit on an R32 GSTt, i imagine your 200SX could swallow a much bigger wheel ;)
I like both, though i suspect my Model 6s would look better if they were white against the silver bodywork...no need to apologise, wasnt any trouble, good to hear you got the problem sorted.
https://www.sau.com.au/forums/topic/28740-which-wheels/#findComment-593229
heeey that's my pic! :D
y'know, if you'd just showed pics of 2 types of rims, i would have said the silver ones straight away. But on your car, i like the gold ones...they actually made me think how nice your car looked, instead of it looking the same as every other silver R32 :)
https://www.sau.com.au/forums/topic/28740-which-wheels/#findComment-594205
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
