short of writing the facts down on a wooden stake and literally bashing them into your heads with a hammer, I don't think that there is any other way that Gary is going to be able to get the facts into some of your very thick skulls :D
One thing that I really did learn from this thread is how much of a dead set idiot you are.
Are you sure you don't drive a Holden Commodore with a Southern Cross sticker in the back while you wear a straight edged brim hat tilted slightly to the side?
Besides proving my point by being an idiot, what is it that you are trying to achieve by posting the replies you're doing in the thread?
I don't think he even understands the concepts being discussed. Trolling is about all there is to it.
Judging by your off topic replies, once of which is a feeble attempt at a personal attack ([200] that is one of the most pathetic insults I've ever read on SAU), it is in fact the two of you, who are trolling.
I'm merely saying that some people should re read the facts which have been reiterated again and again in the previous 40 odd pages, but are seemingly immune to changing their POV on a particular subject.
I was expecting a reply something along those lines, absolutely pathetic.
Maybe one day you will achieve something in your life and your parents will no longer regret that you weren't just a cum stain on the bed sheets.
LOL.
well once the trolls and continual nay sayers accept the fact that a 13B actually flows 3.9L and revs to 3000RPM before the eccentric shaft, then the thread is finished! until then the debate continues!
What you call fact I say subjective opinion...the length of this thread is evidence of that. But really, shut up man. The debate finished a long time ago...we all got sick of it, even the most argumentative of us. You had your chance for input back then, of which I didn't see much besides you saying who is right and who is wrong. Why try to reignite the fire when the thread is long enough as is? It sure sounds like trolling to me.
Rotor spins at 3000RPM = Yes, no body argues that and was settled a very long time ago.
Flows 3.9 litres...? = It sucks and spits out 3.9l every revolution of the rotory but only spits out 1.3l every combustion cycle
I'll ignore the fact that there are mistakes and say yes, but that is but part of the story. A part which conveniently sets out to discredit the rotary (which is already incredibly flawed anyway).
Everything is relevant to time, everything. The position above totally ignores the time equalising crank/e-shaft and the notion of relative.
This is as smart as quoting torque and not power. Or assuming house prices rise indefinitely because they are high now. Assuming your car is full of petrol so it doesn't need any more again. That not being hungry now means you are okay forever.
Ignoring the arguments of displacement and capacity, the above position ignores time and relatives and doesn't get close to describing how the engine works at a critical point - output. Therefore any conclusions drawn from it are flawed.
It is you who needs to read the thread and understand it.
I have read this entire thread, start to finish, and gary's logic makes more sense than any of yours. To me the simplest way of putting it is that: if a rotary engine does not in fact flow such large amounts of air, then how on earth can they spool such big turbos with ease?
There are 4 seasons to a year, the earth revolves around the sun, humans are mammals, rotaries: revolve 3000rpm, pump out 3.9litres and are 2 stroke. These are all facts. Accept it.
There is nothing magical about a rotary. It does not use any state of the art alien technology. It's combustion technique is unique but by no means state of the art. The fuel it uses is just normal fuel, not any special nuclear fuels. So why in the hell can it produce that much power and use that much fuel if it only pumps 1.3litres? How can it spin a massive T01000000 turbo charger with just 1.3 litres? Use your common sense and logical reasoning people!!!
Mr Skyline Man - i will repost something just for you.
Let’s sum this up in a simple chart to visually explain how this works:
2 stroke engine (up, down) – 1 complete crankshaft revolution.
4 stroke engine (up, down, up, down) – 2 complete crankshaft revolutions.
6 stroke (rotary) engine (up, down, up, down, up, down) – 3 complete crankshaft (eccentric shaft) revolutions.
If its a 2 stroke engine then it only expells 1.3l. If its a 3.9l then its a 6 stroke. So one theory will cancel out the other, its either 2 stroke 1.3l or a 3.9l 6 stroke. As it is quite obvious that its not logical for it to be a 6 stroke and its perfectly plausable to be a 2 stroke then it has to be a 1.3l. If you want to look at it from the rotor's perspective rather than the e-shaft then you need to think of one rotor being one piston that is able to produce 3 operations at once and able to complete three combustion cylces in one rotor revolution.
Don't waste your time guys, you're only posting information that's already in this thread. And they're only asking questions that have already been asked in this thread. All this does is add to the length of it. It doesn't help that they have read the thread something like this:
utter crap
utter crap
utter crap
utter crap
GARY'S POST
utter crap
utter crap
utter crap
GARY's POST
utter crap
utter crap
Mate, there is no 'logic'. There is fact and there is not.
What is your definition of large? It is a totally subject term! The same size as a 2.6L piston engines in a similar fashion? For a 13B? Yes, exactly. Albeit (only) slightly better due to heat. RB26 single turbos can be basically applied to 13Bs. Think T04Z, T51R (extreme) or GT35R!
Many people are still ignoring relatives and time equilisers and only ending up confused (yet arguing based on it LOL).
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
