  Jez13 said:
Oh dear. The initial conclusion to this thread was dicided a while ago. It simply came down to an 'opinion' on what constitutes a rotaries combustion cycle. If you beleive that a a rotoaries combustion cycle is one combustion from each rotor and turning the essentric shaft one full turn then it is a 1.3L (my opinion) or if you beleive that the rotaries cycle is comprised of 3 combustion cycles from each rotor and turning the essentric shaft 3 full times then you beleive it is a 3.9L. In my hypothesis and conclusion I went into alot more detail including strokes, angles and capacities etc. Not going to re-state. Its just new people wanting to re-argue said points and stir the fieces back up again.
Whilst we share the same opinion with regards to rotary capacity...I reckon digging up the thread from a few weeks ago is somewhat hypocritical of what you're saying at the end there :P
Happy Birthday rotary thread. Today you turn 50 and we salute. You have brought us good times and bad times; winners and losers; ragers and dedicated followers. You have taught us the ways of Wankel. May your life be free of piston engine comparison. May your spirit burn on like the oil in a rotor combustion chamber. May your mystery and enigma continue to dazzle the minds of mere mortals.
Love always,
Birds.
f**k what have you all managed 50 pages only talking about chicken cookers??
i dont mind rotors . used in the right aplacations they are fairly good . kinda like a small light 125cc two stroke bike can really hold its own in the right circumstances
the main thing wrong with rotors is all the idiots that think they are the be all and end all of everything. rb30s are getting the same way . yeah what RIPS has done is f**kin off the hook and i love it . its just sad when you see numb nuts out the drags with blah blah 300+kw rb30 in a laurel that is slammed and has nearly 45degrees of camber on the back wheels that goes home on the trailer but managed a 16 sec next week they all talking bout this "beast" that ate all the gtr's
sold my skyline to get back in a rotor *puts flame suit one* i missed my capella 13b monster bridge and 3rd gear donuts too much, i am not biased i love all forms of cars, i had great times in my skyline but the way the power is delivered in a rotor is a great feeling
  • 2 months later...
not entirely true bozodos. You only need to premix your fuel if you have taken the oil metering pump off the engine.
And any rotary is no different to a GTR with regards to servicing. Change the oil and filter at regularly intervals. When you change the plugs use a quality plug and you will be right. I dont even warm up my rotor, nor the RB26 that sits next to it in the garage. We simply drive both cars sensibly till they are at temp and drive them appropriately before we switch them off.
A lot of people will argue that seals are an issue on rotaries..... sure they may well be, but the number of engines i pulled down when i worked at Advan that had spun bearings puts RB26's well on par with the rotary engine when it comes to failures :)
Edited by ido09s
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
