car (2003 m35) drives fine in normal mode, hubby accidentally knocked it in snow mode i got in and it shudders big time when you turn the steering wheel.
is this normal???
does anyone know what is wrong with it if it isnt?
please HELP!!
thanks.
https://www.sau.com.au/forums/topic/289031-shuddering-stagea/
Are you in reverse, "D" or a gear (tiptronic mode)?
I ask because mine used to do it (2 years ago) when reversing very slowly.
Changed to a good quality transmission oil and all was fine.
Just started doing it again recently... but I know I was low on trans oil as I was on my way to get some more.
Maybe check/change your transmission oil for starters?
Is it shuddering like torque steer shuddering?
Snow mode engages the 4wd, like a centre diff lock, and makes the car drive off in 3rd or 4th gear. All of this would make the car shudder at low speeds especailly in a tight bend, but I think it all disengages above 40Kph.
If you drive the car in Syncro or Snow mode on dry hard surfaced roads the car will shudder like hell when you turn the steering wheel. That is the dif locks going "shit" the wheels are turning at different speeds.
Yes, very normal.
If it does it when you are NOT in Syncro or Snow mode it is a problem.
Cheers
Andy
Snow mode makes it start in 2nd gear and reduces boost and drops out above 40kph.
Yes, very normal.
Cheers
Andy
WAS a problem. :P
Yes, very normal.
Cheers
Andy
thanks Andy,
i was starting to think it was a problem it drives perfectly when not accidently clicked on snow or syncro.
sweet. now i can breathe easy lol.
thanks again guys :(
I did it the first night I had my stagea :( . But it's not a diff lock (stagea's don't have a centre diff to lock) but it puts the torque split 50/50 (front and rear) which at low speeds will cause a shudder while turning on dry ground. Do the M35's have a seperate button to engage the 50/50 torque split like the C34's or does just engaging snow mode do it for you? I don't believe just engaging snow mode in the C34's causes the 50/50 toruqe split to kick in too unless you hit that button as well.
The M35 has a single button that is a rocker type switch. One way gives Syncro mode, which is 50/50 split but only to 40kmh. The other way is Snow mode and this does the same as Sncro but also makes the car start in 2nd gear, limits boost and cuts out at 40kph.
  • 1 year later...
When is it advisable to use Syncro mode?
When is it NOT advisable to use Syncro mode?
Can damage eventually be done somehow to the engine or transmission ?
I experienced shudder on the third drive I had which was very disturbing, but reading the posts my car is acting normally
I get some weird shuddering when i am turning right at low speeds, not left only right... series 2 c34
If you are talking about getting a sound like a ball bearing rolling around a tin can and shuddering when turning full lock in one direction could be a cv shaft rooted, thats what was causing mine.
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
