Hey All
Im thinking of getting a black and white theme going on my R33 and going the usual with bonnet and gonig to paint my stockies black.... but was wondering what your thoughts are n doing the petrol cap/cover in black aswell... I like the look and think its a bit different and adds a different look to it...
I have grab a pic of a car and just used paint to demonstrate... All feedback welcome good or bad
https://www.sau.com.au/forums/topic/289889-petrol-cover/
i think it would look wierd but couldnt you find a wrecked black one and take the cover off and put it on yours that way you can change back if you end up hating it.. would prob be cheaper then getting yours sprayed anyways
https://www.sau.com.au/forums/topic/289889-petrol-cover/#findComment-4851675
Ah acually quite a good idea... might have to look into this
https://www.sau.com.au/forums/topic/289889-petrol-cover/#findComment-4851764
I kept looking at that picture trying to think of what looks weird, then it hit me, you did the fuel cap on the wrong side :(
lol yeo.. i couldnt find a decent side pic of a white 33 on google so i just used this one and drew it on in paint hahaha but still gives the general idea of what it would look like
https://www.sau.com.au/forums/topic/289889-petrol-cover/#findComment-4854062
i don't like it, but that's just me
another way to do it without painting it (or having to find a black one to try) would just be to wrap it in cling wrap then put some black contact paper or sticker vinyl on it. that's actually what i did with the front grill on my r33.
i used both white and black decal vinyl to make it look a little bit more like a series 2 grill as i didn't want to paint it and then not like it.
https://www.sau.com.au/forums/topic/289889-petrol-cover/#findComment-4856711
Leave it white mate. I think that would look the best. It would look very out of place being black.
On another note go with the black/look. Just do it with carbon fibre. Bonnet, Spoiler Wing Blade, Window Pillar Panels, Mirrors.
https://www.sau.com.au/forums/topic/289889-petrol-cover/#findComment-4857518
If your trying to get the "Panda" Spec look, your going to have to make a few other things black, so your cars has some consistency with it.
If you must then Cling wrap it like what mad082 said or just leave it.
https://www.sau.com.au/forums/topic/289889-petrol-cover/#findComment-4862199
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
