Putting in splitfires soon and wanted to put NGK BCPR7ES-11's in (the ones that come in 1.1mm gap from factory) but apparently NGK dont make these ... they make BCPR6ES-11 and BKR7ES-11 but NO BCPR7ES-11 What gives?
The BKR type of plugs are 2.5mm shorter than the others so I'm not sure I want those in there .. any particular reason why NGK would have chosen not to make BCPR7ES-11 that anyone can think of ?
  • Replies 41
i remember these were the only ones available a few years back. it used to shit me because i allways had to gap them down. maybe they stopped making them because the .8's were selling more ?
why cant you gap them ?
I could but I'd prefer not to ..we're talking fractions of a milimeter and I'm not sure I trust any mechanic to gap all 6 of them accurately. I'd prefer them in that gap size from factory ...also less risk of the tip being damaged etc during regap.
Having said that ..even though NGK.com.au doesn't show BCPR7ES-11 in their parts list there appear to be plenty of shops that sell them (googled it) ..wtf?
how do you know if someone in the shop or the packagers who pack them at warehouse did not drop the plug or the box the plug is in before you buy it?
you should check the gaps on them anyway.
with the tool designed for it :D
QFT!
Pretty sure I have BCPR7ES-11 gapped down sitting in my RB20 right now :3some:
If you cant find them just use BCPR7ES if you were going to gap them down anyway whats the point in getting a 1.1mm gap unless you cant find the 0.8 which you can get your hands on from your post :D
If your mechanic can't gap a spark plug, find a new mechanic. It's not rocket science.
Even from NGK, you should still check the gaps as you install them.
Are you sure you need a 7 heat range?
I don't believe I'm reading this , if feeler gauges are good enough to set ancient contact points they're plenty good enough to gap a spark plug .
Feeler gauges are a glorified go/no go gauge and repeatable accuracy gapping spark plugs is childs play . We are talking to the thou or 0.0254 of a mm .
Simply open the gap up a tad with a small flat blade screwdriver , insert the appropriate feeler gauge finger and gently tap the outer electrode till it closes up on the feeler gauge leaving a neat fit - bingo 1.1mm or 0.0433" (tad over 43 thou) gap .
Plenty of people have opened up the gap on std plugs or closed up wide gap ones if they couldn't buy the manufacturers set gap .
A .
Howdy again mate, I changed my sparkies about 2 weeks ago. Used BKR6ES 11's I'm quite sure, gapped them down to 0.90mm using a proper spark plug feeler gauge - only like $9 from supercrap. Very easy, very accurate. Just do it :3some: Just put some paper towel or something on top of the hard surface you put the plug on to prevent scratching.
yeah i wondered that myself a while back until i actually looked up what the 2.5mm difference was. as tony has shown, it is only in the top section of the plug. the threaded section and electrode aren't affected. if the springs in your coilpacks were shot (or missing, LOL) then you may have the slightest issue with the lead section of the coilpack not contacting the spark plug properly, but as i said, i don't think it makes any difference in normal circumstances
hmmm, i just changed spark plugs on the 34 gtt
went from ngk PFR7G gapped at 0.7mm to BCPR6ES gapped at .8mm
after the swap i now have a missfire at idle.
i used to run the 6 heat range in my 33gtst with 190rwkw no problem (both cars running splitfires)
i assumed the 34 would be the same but apparently standard heat rang is 6 for them not 5 like the gtst.
So im guessing going back up to a 7 heat range would fix this?
What is the difference of the PFR7 plugs compared to the BKR7ES plugs?
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
