Curious about that too. But I think it might be wise for me fully covered anyway - I generally get fried and tomato-ed by the sun.
Kate burns bad... I do these days, never used to. Spray on sunscreen is great when you dont want greasy steering wheel hands.
  • Replies 306
Posted Images
No good man! Coming up to volunteer?
I would, but I honestly can't afford it. Unless someone wants to give me a lift up and back on the day.
Supra is my daily and I can't afford to have it off the road. Who knew gearboxes were so damned expensive.
Good news for all you randy melbournites :laugh: - Looks like the Grand re opening weekend for Club Rawhide is the same weekend as DECA :wub: They are still waiting for the liquor licence and I was speaking to someone the other day who said it should be through by then
For those heading up Friday: Rawhide have their big grand opening party :D enjoy :P
well the busted turbo came off last night. working one went on after work today. new coolant...again, just after the new radiator.
gave it a quick run, seems to boost. that is all that counts?? its making a whirling noise, so we will see if it lasts.
nothing leaking. all fueled up and ready to go.
bad luck is spreading, i just found a transmission fluid leak and the trans light flashing again :cool: . i should of known something was going to happen, this always happens to me when i think im ready for something BAM! it goes all wrong :) . i hate my car now, who wants it?
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
