  • Replies 14.2k
Have you looked at the hi octane sumps? They look like a serious bit of kit and will be what I go for when I build my motor. Some nice internal gating/baffling too
+1 for high octaine sump!! and yeah, needs a bit of cut and wleding
as far as the tomei sump baffel goes i think its either place or screw fit
yeah thats a shame matty fire takes no prisoners or no prejudices
indeed steve, hardest luck story was from the first photo. The guy who lived there lost his first house in the "white flat" fire 2 years ago. his son built the house for him so he had somewhere to live, and he's copped it again. He said to one of the guys i was working with "they sell houseboats on the murray yeah? might be time for me to buy one of them!"
Whats that thingamajig?
-D
thats a "rural padmount" ground level transformer. only uses one phase from the 11kv system (the one cable coming into the "elbow" on the left). Produces 2 phases of 240v for consumer supply. This one WAS feeding 4 houses, but only 2 were left that could be safely re-energised by generators. Note, that was closed during the fire and normal operation, so shows how much heat there would have been
Hope everyone has/or is having a good xmas,
Can anyone recommend a good place to get guards rolled? My tyres seem to like scraping the guards now...
Edited by skwiz
I need some help. I think I've got an inlet leak.
If I rev the engine up and release the throttle , it stalls. But if I take it easy it's fine :P
I'm thinking it's the inlet manifold gasket ?
Any ideas on how to be sure ?
Lose the hektik flutter.... :D
Luke ENR34 is the man to see for guard rolling :D
any idea on prices?
only because i am too lazy to call them.
youre far too lazy for your own good jake.
About $90 a guard, give Luke a pm first mate
what you smoking james? i want some.
bleh, $90 a guard? jesus.
its only $40 a guard for ns members.
ill have to get my guards re-rolled for the cst's, might just get all type to do it.
Edited by scandyflick
I've heard someone say that 98 Octane fuels offered by the different petrol station brands are different in their makeup, and apparently BP ultimate is the better one to use. Is this true or a load of waffle? Does it really matter if someone uses V Power or BP Ultimate or Vortex 98?
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
