  • Replies 14.2k
sounds like a fun night, any idea who they were?
-D
i know only cause i was told, i knew they were footballers but didnt know their names or who for. all ill say is they play for the crows
i recon james is really burnt his neck blended in to his red nissan shirt lol
Does anyone have any contacts to anyone who does pre purchase building inspections??
off the top of my head, ruby might know someone, so ill pm him..
any one else?
i dont really feel like whipping out the key card for a $600 bill, just for someone to say, ''yep, all good''.
thanks all.
speaking of asking favours, does anyone want to nut out some auto elec stuff for me
took my lights off tonight, took all the wiring out and that, no worries
took the 2 extra switches out. neatly snipped where the power / trigger for LED light on switch were looped from the main spotties switch, and removed. bullbar spotties were still working. relocated switch one row up in the dash, moved the wires one at a time (off, thread through new hole and back on, repeat) and now all the stupid f**king thing wants to do is blow 15a headlight fuses on the drivers side. replace fuse, hit low beam, fine, high beam, fine, spotties on, BAM!
kinda frustrating as i cant work it out :S
I missed AJD :) boooooo
I slept in til like 3:30pm lol. Woke up with like 8 text messages from people being like "AJD... you here man?"
f**k.
pretty much the same thing here.....
got absolutely hammered the night before slept in till 1pm and then got a call from my coach telling me that i am playing soccer lol at 2pm.....and straight after the match i saw my phone with so many of the same messages as yours Daniel
Hmmm yes. Saturday night....
Got home at 3am, filled out my AJD forms, got my stuff I was taking ready, bed at 4.30am. Hadn't cleaned car, set alarm for 6am, didn't wake up till 8 then rocked up to AJD with a dirty car which I cleaned (to a fashion) on the oval.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
