  • Replies 14.2k
i have a ferret and i just brought a pink tou tou she looks predy
i gots 2 ferrets too. theyre funny as hell to watch.
buy ur ferret a lobster costume http://www.healthypets.com/dogcostume.html looks funny as hell when they walk around the place
-D
-D
hahahaha thats wikid!
Interesting vid.
I don't mind seeing a skid myself. However this dude must be a full on attention seeking wanker.
Honestly. I would feel embarrassed if I were in the car with that rock ape. Smoking and actling like hes king.
tosser IMO
What a night it was. Some very weird women at the Palais last night, definatly kept me entertained :thumbsup:
Yes, it sure was. Don't forget about that creepy looking guy that was sussing you out haha. And James..... jesus. Very dissapointed in you.... :cheers:
after the Palais closed we went to another hotel in the hope of Jagers, but no such luck :D
:thumbsup:
this morning on my way to whyalla i had a car accident. the trailer started to fishtale and i lost all control of the car and ended up with the car on a angle in the ditch and the trailer on flat ground.
i was driving at the time and i cant really remember what happened. both the axles are snapped on the trailer and the car i was borrowing a write off. my friend had to be air lifted to hospital with a back injury, he had slipped a disc a while back and they think that the accident has flared it up again. the 31 unfortnatly has some damage, which i dont know the full extent of, all i know is that she is missing a front guard and the bonnet and front bar is damaged from the photos that my mum took.
so yeah she will be out of action for a while :cheers:
Are you ok Cara? Any updates on your friend?
Sorry to hear about the cars involved but your health and your friend's health are way more important. I hope everything works out ok.
I'm working tomorrow - I couldn't goto Futures even if I wanted too lol,
I just got back from Luke's workshop rolling my rear guards, not to get some new tread on the Meisters and were in business for old school and new age :thumbsup:
future music is gonna suck 2morrow, feeling sick and have to sit in the rain by the looks of things. damn adelaide weather
the weather sucks atm hey :thumbsup:
from driving down rundle rd on friday and peeking at the setup, it looks like the stage that i will be at all day may be undercover. Each of the other states have had this particular arena in question undercover too. ah well under cover or not : bring it on!
Only thing that interest me is Above & Beyond but I could just sit at home and listen to TATW and not have to put up with being in a place full of douchebags.
theres douchebags anywhere you go dude, just dont let them ruin a good time!
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
