I despise itunes how hard is it to put music onto what is essential an overrated USB drive? My wifes $100 music player is easier to use then anything apple produces
I don't understand how telling ITunes "this is the directory my music is in, now add it all to the library" is hard? I think it is awesome.
And I was more talking about the App Store than ITunes .... anyone over 15 and has a half decent car stereo rarely listens uses their IPhone for music anyhow IMHO.
  • Replies 14.2k
That would be sweet man. Might have to see if matty can drop it down.
Anyone else have trouble writing in the reply box on their iphone? I touch the box to type and it does nothing, use to work fine when i first got the phone
Edited by DSTROY
I dont have any troubles. Maybe try clearing the internet cache? (Settings -> Safari -> Clear Cache)
Fu*k yeh. ARC cooler with hard piping kit just arrived. Has HKS silicon hoses and a greddy intercooler pipe.
Jake like this. Putting the casino winnings to good use i see?
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
