spotted: ECR 33T this morning on windsor rd near baulkham hills....
sam the new rims look awesome.......
werent you going to go wakefield today ?
New rims?!? I demand pics Sam! hehe :P
My white r33 seems to have stealth mode turned on too. How do I turn it off?
wil..
New rims?!?  I demand pics Sam! hehe :(
wil..
its an irreversable option on some '33s.... :D
yellow personalised plates :D
I'm in FA :(
I always park in the multideck.
wil..
i try to park wherever i can find parking aslong as it's covered.. i used to park outside with the other red r33 s2 and a black gtr.. but the threat of hail scared me.. there's always a nice silver supra parked on level 4/5.. but i dont get why the foglights are covering the fmic air intake...
Pete
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
