Just picked up a hot guy in a black r34!!  he took me for a spin around the block!!!  that car is sooo sexy!!!!  his plates are DHC... is that anyone from here?!?!!? :)
geez...took some strange chick around the block hey ??? what was he thinking ???? :D:)
Spotted a red r33 GTST series 1, with a weirdly places GT style wing (rear end of the posts drilled into the stock spoiler, front ends dangling) driving past Purchase Road.
awww...all you guys have been having skyline fun. I haven't :). All I've done is change my oil and oil filter....
Saw GTR-10S Silver R33 GTR yesterday arvo...I was in the silver R33 GTST Series II, gave you the thumbs up when I passed you as I went through the roundabout on Metella Road. Seen your car around a few times in the last few weeks...nice ride :P
spotted dark grey S1 R33 GTST p-plater with Nissan Pulsar N13 SSS plates MON-52L following.. heading north on epping road :D:)
also spotted a R33 GTR blue one heading north on homebush bay drive.. gave a smile and a nod.. what a sexyyyyyyyyyyyyyyyyyyyyyyyyyy looking beast!
hahaha.. .hey.. i was in my 'line today and i saw a holden gts... plates were MISGTS.. i thought MAD!!!!  It was being driven by a hot blonde chick.. i grinned on passing.. she looked... stuck her nose in the air, then looked away!!!  what a snob!!!! lol!  i was giving some respect to a fellow chick driver and thats what i get! pft!!  :D
chicks can be cruel can't they.... hahahaha...
spotted what seemed to be a cute strawberry blonde girl on a mobile phone in a Burgandy R32 GTSt stopped at the intersection of Kissing Point Road and the road that goes to Telopea, she seemed to be goin towards silverwater road (from james ruse drive?). This was at about 8pm?
As she drove off I could hear a BOV (not a supersequential dohickey, but a regular non fluttering atmo). Not bad... not bad at all...
think the numberplates were SWZ 114 or something I couldn't read it properly as my light turned green as she went past me.
Cool :)  Didn't notice any other 'lines in there.. Hear my squeaky noisy fkn annoying damn new brakes?
hahaha... No I didn't hear them. I was parking my car and I looked at your car and thought... Where do i know that car from.. hahaha
I parked my light blue TP magna oposite. :D
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
