SPOTTED: on old pac hwy a white r33 boosting up the hill ... gave each other a wave as i was going the other way with a coupla frenz
Finally been spotted!
We ended up in Wollombi for a bite to eat then headed back to Sydney. We saw emergency vehicles fly through Wollombi later discovering that we had missed a bike accident by literally minutes on the way there. It was around the bends after the observatory.
See you around
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
