Spotted R34 plates R34 lol on george st last night...
i was in the black r32, my mate was talking to ya, he said u worked in some building near him....
I didnt work there man ...i used to live in rockdale ..i thought he said that i lived in rockdale ...
Saw Black R33 GTST 'VIS33R' inside Barrenjoey High School, Avalon today. Guessing your one of the teachers?
pretty sure that is big vis from the forums, but I haven't seen him on here for ages
i think i saw u sawakita :D
on epping road (actually i think it turned into beecroft rd) going in the opposite direction toward beecroft. this was next to epping station after the tight bend.. would of been around 11.30
didnt see the number plates, but it was a hot looking white r33 gtst s2 like the one in ur sig..
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
