Spotted lots of hoons on Geroge Street.. All driving there mum's small little pulsars with there speakers up loud... LOLOLOL.
Anyways spotted manu "R34" on geroge street going away from circular quay. I was on the bus lane (Traffic was a bitch tonite), I gave you a wave!!!!! :( didnt see you wave back, was gonna have a chat but i had to go.... How is your suspension? Did you fix it up after that wrx incident?
last nite around 1:40am i spotted a silver gtr r32 Vspec 2 he was comin out of M4 heading towards the CT^^*via parra rd..
lol he had a HKS SSQ BOV .. and saw him givin it a hit at the light infront of bunnings warehouse
i think the car just got complied not long ago... beacuse of its plates
That really sucks, I hope you are OK, something like that would really shake my confidence on the roads. I remember that happened to another driver on here a few years ago.
Anyways spotted manu "R34" on geroge street going away from circular quay. I was on the bus lane (Traffic was a bitch tonite), I gave you a wave!!!!! :D didnt see you wave back, was gonna have a chat but i had to go....  How is your suspension? Did you fix it up after that wrx incident?
I did see you wave but you were so quick ..you stopped and looked back and waved and gone ..i did wave but you were too quick....Yeah the suspension is fixed had to get bushe...its all good now...
Thats good to hear its fixed.
Didnt want to hold up traffic, as I was in the bus lane.. whats the fine? $250 or somerhing? hehe...
Prolly didnt see you wave coz my tint is soo dark... :D
Howdy there northern neighbours :rant:
Whilst in your fair burg on the weekend I saw a nice white 33R [GTR-888] in Bondi Junction - I was the guy on the bus, perhaps you saw me ;)
Also saw a gunmetal 32R with a huge wang and yellow personalised plates - something 'cutie' or 'cute' or whatever - was parked in Bellview Hill.
Hate to say it - but those yellow plates aren't the best.
The new European style ones look cool - but too long for imports. Bummer.
James
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
