spotted MSP-25T :D
moans, i horned but u didnt look... u must of had ur music up loud or something ;)
this was tonight around 7.50pm at the end of james ruse dr.. u were turning right to go towards granville and i was turning left
GET OUT!!! you were on james ruse turning onto parra rd?! i missseeeddd youuuu!!!!!!!!! :D i did spot a 33 just a lil down parra rd about 2secs later!!! can't believe i missed you ;)
NNNNNNNNNNNNNNNNNOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO /darth vader
Hi, I think that was me : )  , were u in a series 1 right ? Good to know u acknowledged  coz i waved to mostly non-wavers recently ^^
Tell me about it... It's turned me into a non waiving bastard! :)
But yeah, was definately me. You live anywhere near that area??
Burnsey
spotted sexy 321 GO on penno rd this evening :D hehe.. sorry for the fly by!! i was in such a rush to catch up, i couldn't stop by the time i got to you! lol!!! and all the beeping was cause i thought you were going straight! i'll be more subtle next time! lol!!! good to see you and the car though! :)
spotted ONISMO silver r33 gtr at macquarie uni, see it all the time, nice car but has had a bit of damage to it, not bad though...
hey i see that GTR all the time! do you spot my black r33 with VS front kit and GT wing? i usually park in the open carpark behind the bus stop, what colour is ur 33?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
