damn, thats a lot of lines being spotted..............i feel a bit left out here guys lol.....$10 to anyone who spots me......im desperate for attention.................................anyone...............hello?..........lol........
Yep, that was me.
Saw you in the white 32 gts-t :P
Also spotted MAR-55S, who i believe is also on these forums, turning onto the M4
Just saw a r33 gtr ? gts t near ryde on monavale raod with art 97???? number plates and a www.sau sticker on the back, Played in the traffic and gave it a wave. Nice plates, mine are art 40b...... :huh:
Yep, that was me.
Saw you in the white 32 gts-t :(
Sweet finally spotted and got spoted!!!!
nice work tommy!!!!!
Spotted a r32 GTR with a silver front mount in Neutral Bay.
A r33 with rusty calipers and distinctive plate in North Sydney .. looked kinda dumped cos I wouldn't park a skyline there and leave it sitting for the amount of time it would take for the calipers to get like that.
r33 4 door around the Forest area.
Spotted and drive with a black R-32 (rego "321 GO) on the Bradfield Highway and Epping Road approaching the start of the M2, at about 2.30am Sunday morning on my way home from the city.
Spotted a white R33 on Briens Rd Northmead this arvo around 2:30 -2:45. Had a SAU sticker on the rear window.
I beeped as I went past but was in a Mitso Mirage <---- did I say that out loud
I think that might have been me!
...maybe. I know I was around that area at that time, and I heard a beep. I was looking around thinking, "wtf!".. lol
keep it wilb.. it adds character!
spotted YLM xxx this morning on the highway! (just so I'm not whoring!)
oh also ATN xxx gunmetal 32 gtr.. on elizabeth st on sat night. I'll be visiting you for more parts soon!
do what i did and put your stickers on crooked and get your skyline to do something crazy, like mine (squatting madly) :)
cept i still haven't been spotted. So im gonna spend about $200 on SAU stickers and cover most of my car in them..... That'll be pretty f$%king hard to miss
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
