heaps of cars out today...
spotted a white 33 with kit and rims near centennial park....
gunmetal r32 near randwick race course... another white r33 near fox.......
heaps of wrxs and 200s out for the tigers game too...
someone spot me dammit!
Ed
Wilch
"Saw a 32 GTR on the Cumberland highway too. It had a cf bonnet, and gold dished rims. "
that would most likely be UREADY as i spotted him on
milperra rd/Newbridge rd...i was in my work car with my mates..chatted to him to say congrats on his 10sec pass ;)
spotted ranicx on bondi road thisafternoon stuck in traffic ;)
spotted another sleeper R33.... pretty stock but went well and blew a hell of black smoke on me when gunning it..... this one was ED and anzac :)
Anyone seen me yet??
i spotted a white cefiro on victoria avenue chatswood out the front of car wash cafe. I actually saw you twice. For once i was in the GTR instead of the soarer :D
was it you CC?
was it you CC?
I drove past that one also, nice looking Ceffie I must say.
Spotted lots of Skylines up in Sydney yesterday, ost noteable being a silver R32 GTR with silver dished wheels and a CF bonnet and a white R33 GTSt with a big Nismo sticker across the windscreen and 400R kit.
I have no idea what road I was on though as I was extremely lost :D Was heading from Blacktown/Windsor area towards the M5 to get back to Canberra. Would have been around 1PM.
EDIT: Forgot to mention the guy in a stock-as-a-rock E36 318i proudly displaying a very crooked M3 badge on the rear as well...
Edited by Amaru
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
