hey is your plate SPO-0LD ?
Im at unsw as well...dont recall seeing your sky around....
SP.00.LD
I drive maybe once a week, and if I do, I park lower campus (eg. on the other side of Anzac Pde).
spooted a R33 GTR with R34 GTR rims on victoria road westryde.
and i think i saw rukus @ jamesruse drive..
turn off into victorai road.
taking that corner abit hard :)
hahah I love that corner !!! always give it a bit of a hit coming out of it.
Spotted Liz boosting pass me on Pacific HY Artarmon around 6:30pm. Caught up next to her and said HI :P
i thought you were beeping at me coz I pulled infront of you... i was about to stick my finger up!!!
nice car champ!
Spotted a purple GTST (I think) infront of Powerplay an hour ago. Waved at him, and he waved too.
I was walking to my car at the time. :P
I didn't pay much attention though. I shouldn't have gone to Powerplay. I ended up buying something! eek!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
