I saw and waved at a White R34 GTT on Old Windsor Road (at the lights at the end of the M2)... he gave me a toot back :rolleyes:
Nope, Silver, mine is dark green...
I saw one last Monday (6 days ago) at BP Seven Hills... had an exhaust and sounded nice :P
Was that you??
I saw and waved at a White R34 GTT on Old Windsor Road (at the lights at the end of the M2)... he gave me a toot back :P
I saw one last Monday (6 days ago) at BP Seven Hills... had an exhaust and sounded nice :D
Was that you??
Hey TommO,
yeah, if it was the BP on Abbott Rd, that was probably me! And I've just put the SAU stickers on the front and rear windscreens, too. Fueled up there last night too.
What were you in that night?
Cheers,
Nick T.
Hey TommO,
Cheers,
Nick T.
Thought it would have been - I was eating with a few mates at Maccas, and we were all listening and suprised when we heard your car was manual :D And then we talked about Stageas for a while :)
I'll come up and say hi if I see you there again :)
See, you've been spotted :P
spotted BKLEUP on Castlereagh st. on Sat night, very nice zorst note mate. Also spotted white R33 going opposite direction at Gouldburn st at Wolrd Square, gave a flash and got a thumbs up back  :blink:
hey mate, yeh i think thats was me, do you drive a (i think its called) midnight blue series II? if so then it was me on goulbourn street, nice ride!!!
haha no dude, mine is black but it could look blue probly coz I didnt give it a good wash :lol: . First I thought you should have similar mods to mine until I read your sig, hehe I would have no chance.
LOL, yeh ive got some power behind me, but the car looks like a sleeper hehehe.....
Spotted a silver R-33 GT-R coming off the railway bridge in Toongabbie this afternoon, number plates possibly GTR-100, at around 5.30pm. He/she gave it a little stab as they headed towards the lights near the station.
spotted a nice R33 GTST on the GW near stmarys thiink hes forum name was sicko nice car mate was in a hurry to get home for lunch or i would have followed for longer
Edited by blk180
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
