oops I got confused with elizabeth drive, I know your car I have seen it a few times in the morning on the way to work.
How about a wave next time :P Also, crashed into any houses lately? :P
*runs*
How about a wave next time :P Also, crashed into any houses lately? ;)
*runs*
I dont wave to anyone because it would be embarrassing if they dont wave back lol
you could have waved to me first :D
do you go that way every morning? because i have seen your car a few times but it was before i got my line
:( nooooo i havent crashed into anything for a couple of days
Spotted very nice R33 "AMS-***" this morning on Forest rd Bexley.
Black looks tough on 33 and love those gold brembos they're huge!
I wasn't sure if it's GTR but it sounds the goods. :P nice one.
alright spotted a million skylines yesterday (as everyone did) but in particular the follow...
32gtr @belrose -atn40* i think, anyway, the dude that was on the nasho run!
TommO on the warringah freeway!!!
aaron25det @ pac highway chatswood
How about a wave next time :P Also, crashed into any houses lately? :)
*runs*
*makes angry noises*
you picking on my girlfriend... aye! AYE!@#!!!
let's take this outside.
:lol:
I only go that way if my on ramp looks like it isn't moving.
I might go down that way all next week though just to give u that wave :)
What did u drive before u got ur line?
you could have waved to me first  :unsure:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
