What suburb? Might have been massiv or me... lol
:lol:
No idea what Suburb..
It wasn't massiv, cause we just came from his house and his bro was borrowing his Skyline.
I was on the other side black R33 with L plates.
wink. do you live in chatswood.
i always drive past you getting lunch at autobarn. :P
your car is parked down the road from chookas near the twisty trafic calmer.
I'm there that much I might as well live there - it's my girlfriends place :P
Spotted a silver stagea in hornsby, sau sticker on the hatch,  he gave it a bit next to me and a supercharged V8 soarer.
Hehe, yeah that was me. coming back from a weekend in Newcastle.
Spotted a white R33 with SAU sticker on windscreen crusing with me in Maitland, also a black R33 in east maitland gave a wave to, got one back
Spotted Doodz in central last night about 5:30 when I was going to Jamiroquai.. I was on a bus :P..
I think it was you anyways.. caught the -33Y and looked familiar.
ah yea.. that may have been me.. Did u see a white 33 behind me? It was rancix's car. unless you saw me after we parted ways.
How can u not miss a skyline with number plates "TRD"? hehe
spotted a stagea at toongabbie/girraween area :)
Spotted Ruk while he was spotting me (in his rear view mirrors) in and around the Tongabbie/Girraween area. Are you a local to this area, or just passing through?
Nice car, dude!
Cheers,
Nick T.
Nice car, dude!
Cheers,
Nick T.
nah i was at unigroup engineering yesterday..
thanks mate.. ur stagea was nice too.. i think it's the first stagea i've spotted ;3
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
