This is a CAR spotting thread...not a PEOPLE spotting thread....
mods please remove :)
hehehe
It's ok to spot members :D Unless one of the mods is trying to reduce the attention one or 2 members have been getting lately :blink: mwuhahaha :)
oh yeah also spotted jef-33r just near west ryde maccas on victoria road...
on tuesday....
I THINK he is on sau isnt he ??
Spotted jef-33r about an hour ago on Silverwater Rd... Bit of frontal damage - ouch!
I take dat on the way home but im ok no accident, dat was a months ago?????
i fix my car already, it was a small dent, i changed my bonnet wit a vented on.
Hmm ok weird... I had a glance at the front of your car, and it looked like your front bar was badly scratched/dented...
It must have been the heat making me see things :rolleyes:
yeah liz
made sure i waved this time hahaha
lol!
I was getting a few dirty looks from the pedestrians as I beeped to get your attention, I should have probably waited until I passed the pedestrian crossing before I beeped! lol
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
