I see a whole lot of skylines all the time but i get tired of waving and getting a blank look back....so if i EVER get spotted and i don't look.... that's why.... there's no love.
spotted a burgundy 33 on kingsway at Caringbah (is that even its name)...got a wave, very nice car man, I never even thought that teh s1 wing even had a place..but your car looks awesome!
btw.. i was in the white 33
what about teh grey and black 32's with them <_<
if that was us you saw lol
lol i think i did see one grey 32, but the majority were all white 33's. It would have been around 11pm
yeah that was us
grey 32 gtr
my black 32 gtst
I think 4 white r33's
and a white r34
spotted a nice bayside blue R34 GTR vspec ii NUR plates NUR-666 @ around 3pm in Petersham
Sure that wasnt NUR-66R?
I saw this one yesterday afternoon parked in its usual spot on the main road in Newtown
Beautiful car that one.
JET#$R coming back from old pac on sunday arvo
sorry dude I forgot your name!! My fault! :):D:D
Your car looked and sounded very nice mate - awesome ride!
Cheers,
Chris
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
