Haha, you'll probably spot my car a lot more this week Jackie; handed the keys to Mitch last night :(
Yeah me and Mitch have already organised a BIG cruise session for that.... HA HA HA HA Just jokes :D:)
Spotted MAR55S yesterday in wollongong!
man im always seeing you out here! are you stalking me?
Speaking of MAR 55S, spotted you parked on the footpath in campsie a few days ago, had to fumble for the sunnies, copped some serious glare from those rims of yours.
Where did ya see me and why didn't ya say hi man???? I was...once again... on a 300ZX cruise and had the Line coz GF's 300 got smashed a few weeks ago and it's getting fixed. While we were @ the lighthouse. we saw about four different Lines.. you may have been one of them... there was even one, a GTsT with GTR badges on it. Obviously... we laughed :lol:
Hahahahaha! sorry man... footpath.. me??????? NEVER :ban:
yellow r32 gtst with front bar in primer on the great western around 5:30pm-6ish yesterday arvo.  and a black gtst IGR-32T same road opposite direction thisarvo.
cool i been spotted for the first :D ... just going home from work.... i was the yellow 1
spot me back then:P
what turbo and BOV do you have?(your car sounds good)
also seen a black 33 outfront of kingswood station all smashed up.
and FEAR on the grt wstrn just before st marys(sounded good)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
