I spotted my car at powerplay :dry:
Spotted DIF's car at her house. :D
Spotted Adam's car at drive ins. :rofl:
Thanks Vic about time someone spotted me, and if anyone else wants to spot me i'll be at the trackday at wakie on the 2nd july, please if you want autographs just make a line and i'll get to you all soon enough.
Spotted Thomas on Victoria Rd zooming past, then spotted him at powerplay. Nice rims :dry:
Spotted a black 33 with standard plates kingsford going up rainbow street from the 9ways round about around 6pm.
So many lines esp dark ones in this area now. sux0rs :( Might have to respray the car blue or something. :
I HATE YOU TOO :P
Nope not me, and there is a botany road @ kingsford? :D
Botany street.. whatever the hell it is!
I spotted my car at powerplay :rofl:
Spotted DIF's car at her house. :)
Spotted Adam's car at drive ins. :D
:rofl:
Hahaha.. when? you did not.. im at work.. so the car is here! hahaha..
spotted FR34KY last friday nite
had to post here cose i was very amazed by the look of the altezza rear lights... couldnt distinguish wat car it was until we got close! i was in the black S2000 behind you at near the JayCar turn off at yagoona.
Thats it, I spotted nath95 in my driveway, damn sexy car and the owner!!! man if i were gay i'd jump that sexy mother fcuker!! :D
:laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
Spotted adam at Blacktown drive ins last saturday, and at oran park on friday >_<
spotted a white 200 with the plates "OFDHZY" in my rear view mirror as i fish tailed away from it, ha love it wen u mall a car that thinks they are all that :whistling:
:wub: gotta love wheel spin in 3rd hehehehe
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
