It was just some council targeting us "hoons" by playing opra style music in the areas in wich we like to congrigate. There were mostly shit cars, and ppl dancing in front of shit boot installs with cheep subs, however there was one nice car wich had abtou 5seconds of footage as it drove of wich happened to be the yellow R33
yeah its a beast.
where did u guys head to? I have never seen so many GTR's on the road at the same time,it was an awesome sight.
Loved the R34 :)
not that there is anything wrong with the gts-ts
where u there too,if so which one was yours?
yessum, was in a white 33gtst
spotted a sexy blue R34GTR vspec, at brighton on saturday... plates were GTR-26V *drools*
oh I've seen that one around a few times.. very very nice!!!!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
