'sif not, Mars... C'mon, you know you want one! Just think of all the extra vinyl you can lug around - I've been there and can attest to its crate and equipment lugging capabilities...
sif Vinyl.. 2006 man! i carry a laptop.
do you use finalscratch by any chance?
spotted some poopra sprinkled between some skylines... and some nutter in a maxima.
1.21.2 is my best so far in race spec, first time out in the skyline...I think it has more in it once it has a tune
thats pretty good man, wat sort of mods tho? like tyres etc?
the car is pretty much stock....stock turbs, stock boost (0.8bar d'oh), stock brakes, stock injectors etc etc. Yoko A032R are the control tyre. Has some jap coilovers. Thats about all.
I'm doing OK but the BSM GTR was quicker in both races I did last year. Missed the whole season this year but am ready for a big year next year.....doing the 10 NSW rounds, and we've just put the entry in for Targa Tas too.
Who is your mate? there are a few commodores out there but in a different class.
also spotted marssssss in teh city...
2GU UP near my place on my home... loving that car anth :ermm:
and DUNCAN: my mates name is Mik, not sure on his surname, he drives a white commodore, usually up the front of the field....if u show me some pics i can point him out, coz iv seen ur car in some of the pics he has, in the forground and background.... he's usually up there with u and the other GTR... hahaha i saw one pic of a race start out at wakie, and all u cud see was the 2 GTR's about 60-100 m ahead of everyone off the start lol... go the 4wd :happy:
Spotted a 32 plates 'FLY-xxx' absolutely SMASHING the industrial area carpark out the back of my place. Sounded like a good solid 2 minute burnout. There was smoke over the joint for about 5 minutes afterwards. :happy:
Spotted a white R33 (series 2 i think) with Dark rims, looked a bit like R32 GTR rims, and an R33 GTR wing just then at Sylvania heading towards Tom Ugly's Bridge
Waved, but i dont think the driver saw me
spotted '32ZILLA' at livo kk carpark last night lol .parked right next to me, also a white 34 gtt, gunmetal 32 gtr and black 33 gtst says 'fussys' on his cooler.
oh and it looks like theyre opening a harrys hotdogs there too. :)
Note to all, if you were in the city last night and got told to do a burnout by a drunken moron, that was me, every skyline etc i ripped into and tried to get a show. Another Note to all, you are all weak sauces and no one bagged it up!
Spotted alot of 33s in city last night
smokey in coogee today struggling for traction you hoon!
ummmm thats all i can remember after last night
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
