hey dif
Haha thanks..
Yea sorry i was abit spastic there.. lol.. so tired from after work.. yep it certainly is! how FILTHY was it!!! :)
oh, spotted a white 32 gtst with racing numbers on the door - was yesturday - i forget where! mid afternoon sometime
my car :) I saw you but Wil didn't
I still haven't taken the numbers off from the last track day or washed my car since then :P
FAT-32R black r32 on Dunheved Rd thisarvo 5:30ish
was in the green excel.
and a yellow r33 on the crime investigation channel at blacktown station.
edit: also the green Stagea that works near me with #plates STAGEA
and the 2 toned silver r33 with 4stud wheels i noticed.
Edited by RSTME
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
