Silver 33GTR with CL ### plates... headed down Mt Ouzley into Wollongong very sedately, stuck behind a slow truck, I gave you some room but you decided to wait...
one very clean ride!
I've also seen a yellow 33 and a black 33 GTR (i think) coming down there too
And a Black 33GTST stopped next to me at the lights in Wollongong near Masters Rd, chick driver, older guy in the passenger seat.
I didnt think to catch the plates.
Edited by B. J.
Spotted a Maroon 33 GTR with huge "Buddy Club" stickers all over it
Also spotted a grey 33 GTST boosting past Chatswood station..series one i think.
Also spotted an S15 with the "Ikeya Sequential" H pattern convertor thing. Man that thing looks chunky....i like it
Spotted a silver and two black R33's (all GTSt's) and a silver R34 GTt sedan heading down the F3, Pennant Hills Rd and the M2 on their way to Friday night drags at EC.
All Central Coast and Newcastle people, apparently...
Spotted Primordial on Monday just leaving just jap!!!
o o o and B-mans Cosmo outside Hitman on Monday night! Looks good! Man those brakes, they are MASSIVE!
Hey! What car were you in? I remember seeing an S15 going the other way when I came out..?
Hey,
I was the R34 GT-T Sedan - I actually live in epping but I work on the coast so hang with them mostly.
Thought it was Goldzilla car but on the two ways the others were thinking of someone else, till that talked to ya.
Drew.
I was in the car behind the s15..... which was the Proton :( lol
I must have missed you by less than 3 mins!!
Hey,
Drew.
Hahaha, hey Drew. I was driving, and my cousin (his username is "blukie") was talking on the UHF CB's. Didn't get to chat for long because the batteries went dead on the CB - I think I've had the same batteries in there since I bought the thing years ago (it must be at least 4 years)...
Who was it that said my car was the "green Camry-looking thing..." over the CB's? :(
Even worse is that someone didn't know what a Stagea was - there are a few up Newcastle way, and they are on the forums too! :ninja:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
