Sam, it was parked in Franklin Street. Although I didn't get too good a look at it, I'm sure it had chromies (nothing too over the top, thank god) and a rear wing on it - I'm pretty sure I would have recognised your car even if it was from just a quick glance.
ah cool.. yeh def wasnt me then lol
spotted some dark colour 34 4door i think parked around the corner from me in the dark near the park.(Get a Room) LoL
and a silver r34 BBZ *** come hooning past me on Doonside Road
not even 5minutes ago.
spotted a few imports in the carpark on my first day at work today :)
also spotted caine at MAC center at lunch today... didnt get the chance to scream out or stop u.. i was going up the elevator wen u got to the bottom lol...
mainly s15's no lines tho :D
Edited by mass_iv
mainly s15's no lines tho :)
*clears throat*
Spotted Marsss on Parra rd near Petersham heading towards the city.
I was in the Hiace going the opposite direction, hahaa beeped at your for aaages..
yeah got the SMS.. as you can understand.. if a Hiace is beeping at me.. i ignore it with gusto... but i'll know next time :rofl:
y is it everytime i spot somone they're never a member of SAU?!? I've been meaning to actually send in my membership form/money but i've been out of work (its been really hard because my skyline needs some work done and i can't afford it) I think i've figured out y i haven't been spotted...because it looks like a piece of junk with bad paint...i just wish i had a decent looking 'line!
I think i spotted security today at lunchtime outside subway/oportos off canterbury/milperra rd
If not, it was a yellow 33, bodykit - plates started with auf i think
I was the guy driving the gunmetal 33 >_<
you'll find that alot of the cars here are a work in progress mate. mine being one of them. took me a while to get the paint sorted.
I was the guy driving the gunmetal 33 :)
yeah mate that was me, i saw you but didnt get a wave or anything so i didnt think too much of it. and when you see a bright yellow r33 you KNOW its me, not think :domokun: . my mate [username: vexed on here] was there too with the blue r33.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
