Spotted a black 32gtr and then a grey 32 gtst not traveling together but about 2 minutes inbetween on the old pac yesterday, heading northbound, a little more faster guys and you'd have caught up to a porsche gt3or2 doing very high speeds.
Edited by Angus Smart
Spotted msnismo today at heaths house.
+ a silver r33 at chittaway. flashed - got a blank stare
lol... you spotted my car but I spotted you around the corner near Ourimbah station heading towards Gosford.. I was in the wrx... no wave as per usual :) Seriously... how can all you guys miss the wrx! *chucks tanti* :(
Although..... I have seen you glance shyly :domokun:
I was inside that bitch last week :P
oh shit
i think i may have been singing
hahahahahahaha what were you singing?
Avril Lavigne's 'Girlfriend'???
spotted marsss this morning on grand parade in the bloody traffic, pretty much followed each other to waterloo, i was in works ford wagon :D
I HATE that friggin rd... at that time of the day.
was behind a blue 33 with rims yesterday around 9pm or so, dont remember plates **-**-** on the way to my mates place... he lives near macquarie uni... nice ride if your on here :) saw a couple flames jump out at me :)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
