Spotted white 33 GTS (possibly GTST.. badge looked blue) on Old Windsor Road around 6:30pm tonight. Plates: LAMB0S
If you're on here, I was in the Corolla that you were following some of the way from the Cumberland Hwy, and then booted past you later on towards Seven Hills more.
Spotted moooooooooooooooooonddaaaaaaaaa..
well Mona spotted me and then beeped her horn like a crazy person .. lol
hehehe.. what about the flashing lights :whistling:
caine was on the phone telling me off for excessive beeping.. oops.. was a lil excited! :thumbsup:
Spotted white 32 with carbon bonnet in towers plates grr something something something
Spotted x2
Right after some c*** copper pulled me over in the carpark thinking I was tearing round the lot, when it was the bloody commodore coming down the ramp.
just spotted a midnight purple 33 gtst with a gtr wing...big chromies...on the back of a tilt tray
anyone here?
plates were "PUR . . . " didnt catch the rest
If it has a red leather interior and its the one im thinking of its packing an R34 GTR RB26 under the hood !
Havent seen him around for ages actually....where did you spot him ?
Spotted x2
you seem like the type...
spotted a blue 34 gtr in Galston Gorge this morning. hothothot
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
