Spotted Zilch when I was leaving work this arvo..... sounds good!
Spotted Lizzeh @ St Ives.... waved but after I spotted you in my rearview mirror!
And a white stagea on Pac Hwy @ Chatswood........
Spotted the autostyle R32 GTR in the back streets of beverly hills tonight, followed by a white R33 gtst series one auto
Then on the way home - another white R33 gtst, but not auto - it sounded really good, i tried to say hello but you turned off the highway to early
myself and a mate in our 31 GTS1's went for a photoshoot down on Pt Kembla (just south of wollongong) some douche in a white 33 thought it was fun to come along side each of us and drop a fully schit dose, shoot off down the road and weave between traffic ;)
Saw a beautiful red 32 GT-R on the way thru Appin on Sunday arvo... it was very sexual, I have a feeling it was widebody.
Saw wraith_skyline this arvo, passing the caltex on Anzac pde just past the uni.
I can spot ya a mile away with those nismo stripes mate, nice. ;)
Haha Sean we so didn't see you!
spotted blue r32 gtr with red p plates and massive chromies in forster maccas carpark 9am
Pretty sure that isn't legal
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
