Maybe if you were in a skyline, I would have noticed :)
;) *retrieves knife from back*
Damn well would be if it was finished :down:
btw... RB powered from factory therefore technically a line by default.... :)
lol will power as in Champ Car racer these days
lol! whoa! That's a bit of a step up. I had no idea. Last time I saw him was when I was a kid at Oran Park with my mate and his dad watching the sports cars and formula fords.
and lol ruk!
Spotted a couple of grey 33s, a maroon 32 and a black 240Z(?) with SAU stickers on it at Thornleigh Maccas last night.
That grey 33 that was stripped out looked good, it's good to see more people interested in going fast! (Mine is even more stripped)!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
