Spotted a silver 33 not sure if it was a GTR it had too many after market body parts on it.. gave him a wave and I got a funny look back. This was this morning over the Gladesville bridge (Victoria rd) at about 8.20am
Oh I also saw a really hot Dark blue 31 GTS with a big fat FMIC on Centennial Ave Lane Cove this morning at about 8.35
Spotted in Chatswood a white R33, asian chap driving I waved but nothing back :P
And spotted Mitch(Mr Moo) following me home :P
did see you at kfc, then you cought up, but the work van just couldn't keep up :rofl:
hahaha! I thought it was Haysey!
Sly work with the camera when I was sitting at Mangrove waiting on the C&I Cardigan Club to catch up. :cool:
Who was that guy that did his front end in just up from the pub?
hahahahahaha blue flame drive by twice lolz
one of the guys had a bit of a skid, nothing too major, he could move it and what not.. just a bummer it happened on the cruise... coulda been worse!
Spotted TJ...........'s old GTR :D
so that means I spotted Matt! Hai!!!
Sorry my head was elsewhere and I was completely not thinking (heading to the hospital) - hence looking at you like "who the f**k is that?"
I'll be more social next time :D
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
