Hey dude i dont really want to spam the thread anymore this will be the last post... pm me if ur interested in anything else :w00t:
Power: 300awkw 1.2bar
CRD (Croydon Racing Developments) tuned it
MODS:
Stock engine, stock fuel injectors and pump, standard cams, standard dump pipes
HKS 3" exhaust
GT2860R-5 turbo's
PFC
HKS boost controller
NISMO FPR
NISMO catch can
CUSCO oil cooler
HKS 100mm FMIC
HKS coil overs
Spotted another V35 350GT today, it was a red one with "Top Secret Imports" shop stickers on it. It was heading through Liverpool on the Hume Highway towards Casula this arvo around 5.15pm.
Yeah theres a few "Top Secret Import" cars floating around, had my car serviced there, it's pretty good :P
spotted ACCESS r34 gtr yestiday driving past newport beach.
spotted an Audi R8..gave it a horn and he waved back :)
spotted BNR034 and GTR34A and another r32 and a evo 6 driving down towards campbelltown on the hume hwy casula.
Spotted a black or dark coloured R33 on Mona Vale Road, bout 7:30pm
Spotted a silver R34 in Gordon, 8:30pm
Also in Thornleigh maccas tonight, spotted an N/A R34 GTR look alike with Z tune bonnet, blue and black two tone paint job and an FMIC not hooked up. :P
