spotted a black 32 on brunker rd at yagoona-ish area this afternoon. pretty sure plates were RR.32.GT. so so clean
i think i spotted this guy too last friday but it was a grey 32 and i think his plates were GT-32-RR so maybe it was some one completly different and just a weird that the plates were the same but different.
Spotted Chubbs, Anna and Mitch this arvo around 3pm
Also spotted a gunmetal 33GTSt with a kit about 5 minutes before, turning off the Great Western Highway onto Toongabbie Road...
On the way home from around Richmond today I saw a black wingless R34 on the M2/Mona Vale Road/Forest Way and...
A certain blue Audi with the number plates HAY 53Y on Mona Vale Rd (I think... it was along those lines, plates where also blue) :P
spotted a hot asian chick in a wingless silver R33 plates BCR-04P
roaming along Canterbury Road in Ashfield this arvo
hi or 'ni hao'/'lei hou'/'kornichiwa'/'sa was dee'/'aneyong asaiyo' if you're on here :D
Spotted a yellow R34 with a black bootlid and black front bumper pulling out of a service station on Blaxland Rd in Campbelltown last night about 9pm. Had stickers on the front door and a large GT wing on the back. Not really my cuppa, but that doesn't matter, does it?
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
