Spotted two Skylines in the space of 100metres and less than 5 seconds - one was a silver R33 GTSt reversing out of a driveway on Fitzwilliam Rd in Toongabbie, and the other was a black R32 GTSt turning left off Fitzwilliam Rd and into Tucks Rd.
Spotted 2 nice white R33s within about 2 minutes of each other at 11:45am travelling down Roberts rd near punchbowl, greenacre. 1 waiting to turn onto Roberts, either a GTR or trust front bar and GTR wing and the 2nd heading towards Hurstville way, GTR wing with a black blade and what looked to be a trial rear bar. Nice cars if you're on here. :D
You should have stopped and found out! :P
You should always look after fellow import owners, especially if they're in the same car as you :action-smiley-069:
I think that might be e-dog on here too, not certain though...
It wasn't that easy. I was in the far right lane, in heavy traffic, and I spotted him pulling into the hard shoulder on the far left just as I was driving past. Not the easiest thing to get over three lanes into the shoulder and pull up during in peak hour.
iam a truckie, i work down in canberra and spotted R33 GTR BCNR33 plates i think it was.. white one
then also an R34 GTR as well as the powerplay imports nissan navara ute
following soon after on the hume highway heading towards canberra..
round 7.00 last nite
very nice looking cars, must have been heading to wakefield or sumfing
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
