Spotted two more this morning. A silver R33 that was way low with 300ZX wheels, I think? Black bonnet and a bodykit as well. It was parked right up the top of Eaton Rd in West Pennant Hills. Plates were TL-0033 or something, I think.
Then a black R33 on the M2 near the toll gates. Looked stock except for lowered ride height. ALC-73X.
while up on surfers last week i saw this sign...... i wonder if we should get a place called "Skyline Central" for NSW, and Vic should get "Skyline South"...?
On the way back from uni
spotted a white R34 GTR vspec with lots of stickers on cumberland hwy near kks, a black R34 4door near Hungry Jacks Smithfield,
a Black R32 GTR near seven hills, and a couple of R33 4doors
to the owner of a black charcoal r33 without the spiler who attends uws parra and who tonight has foolishly left it on the footpath of a main road after 12am accross the road from koala park!!!!!!!!
just letting you know i wouldn't leave my car there for too long so i dont recon you should either
Gold r33 SXY-25T first at RPM motorsport then at the other mechanic on hassall st all in wetherill park.
Oh and the dude in the black 32gtst at resevior lights on grt western yesterday going straight.
I've been crusing my mums camry lately :(
Edited by FATAZZ
Spotted a white v350gt near delhi road...looked clean, sounded good.
except it had a GTR badge and its plates were r35gtr or something.
wasted a perfectly good car.
... as a asian should say. "aiya..."
There's a good chance that's Carls, with the same engine as an R35 GTR, making well over 500rwkw, I think he's allowed it. He also owns an R35 GTR...
but it could also not be his, cause the plates R35GTR is often seen on the Haltech R35... So I dunno... maybe he finally sold it :(
did it look like this?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
