Saw two Skylines today.
-One black R32 GTR parked outside a Hornsby apartment like 2 minute walk from the shops
-A white R34 GTT cruising along Mona Vale Road close to Telegraph Road
No stickers but! Anyone here?
Edited by SEB88Y
spotted a motza of skylines this weekend......
on saturday At kirawee maccas saw SDDR20's r33 in the parking lot and 2 r34's and a r32 around the corner following eachother (i was too stupid to realise the shire meet was on )...
today on sunday i saw a merone r33 gun it on old northern road near the maccas with a very loud bov, and at KFC Dural i parked next to the cleanest black R34 i have ever seen with some very nice wheels....
and a bunch of the cheap not well maintained r32's and r33's in and around bankstown.....(for christ sake look after your cars!!!!!!!!!!)
cheers to you all
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
