spotted alot of lines today can't remember all of them!
- silver v35 and a black r34 at dfo outdoor parking around 4pm
- white r34 with tommy kaira sticker on the rear i think it was stuck in traffic jam along parramatta rd 6pm
- white r33 series 2 i think turning from broadway to parramatta road then towards ultimo i was behind may not have seen me
- white r34 turning towards ultimo outside uts library
spotted a silver r33 S2 next to me from blakehurst to around kirawee last night around 12:30 plates LOZ-87T i think, chick driving with skylinesaustralia.com sticker on the rear window
hi if ur here !
hi if ur here !
Yeah that's Loz. She's a member but not very active :P
Just drove past DRDOOF at Myoora Avenue in Pymble. The car looks amazing in real mate :/
Myoora? Never heard of it... Was it parked, or was I in it? :P
Myoora? Never heard of it... Was it parked, or was I in it? :)
You were parked on it? That might not have been the street. The sign was a bit crooked.
Around the corner from PLC?
spotted a silver r33 going down monavale road at about 11:30 at st ives
also a very nice black and very very clean r32 driving around manly at about 12
gee's i've got a few to write down (but they're from all of last week so yeah sorry)
- Silver R33 in shell servo near bull and bush (think the plates were GOD-21A)
- Maroon 32 near the bull and bush
- Black 33, black wheels, next to storage king in strathfield
- Maroon 33 next to clyde station
- White 33 AWB-85U in Robey St, mascot
- black 34 (plates CK-34-GT) in mascot
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
