Spotted a Nice looking White 33 GTR/White Rims on lane cove rd just past Victoria Rd tonight - Plates were QLD plates - SYK-R33 I think? Also had SAU sticker on rear window.. I was in the Black 33 GTS-T.
Saw the same car, at lidcombe Repco! Awesume car
Yup, spotted you too. That was the first time i've seen the traffic actually going in the other direction on that road lol. Nice ride to mate, reminds of of my old black 33 GTS. Thanks
Spotted a gunmetal R32 GT-R tonight with the plates "2HYPO" on Parramatta Road from around Croydon through to Ashfield. He was still in front of me as I turned off onto Liverpool Road heading into Ashfield, and turned off a few streets before me. It sounded VERY nice. I *think* the driver waved or gave a thumbs up, not sure... I replied, but seeing as either in front of or behind each other at various stages, or traveling at different speeds due to traffic, I'm not sure he saw me reply.
I was in the green Stagea.
Spotted 3 lines one the way home from work yesterday
Black 32 in pretty much the same place I spotted slim
White 33 gtst at the lights next to the building work in Top Ryde
Dark blue 34, was behind it until I turned of vic road just past the police station
Gimpy, I saw that other silver R32 GTR with R34 GTR wheels. He's got some weird grill on it, which is why I thought it didn't have one at all. It looks kind of like an R33 GTR grill. I don't really like it, but hey. Explains why I keep thinking it's you from the side! I saw this one on Old Castle Hill Rd parked near Oakhill College.
Edited by HuH
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
