Spotted R34liner again yesturday while i was waiting to catch the 610 into the city (super stealth mode), made him roll down his window while I yelled that i'm Kujo from SAU lol.... everyone else waiting for the bus just looked at me like a wierdo.... meh i am a little crazy, i drive a line....
also few hours later spotted Shane walking in the city, actually he spotted me around the corner from town hall, had a little chat, then we saw a black r34 gtt while we were talking... lol
Hahahahhahahah!!! - that was classic - sitting in traffic and i get this guy who’s sign language-ing me to roll down my window (i was like - umm its electric buddy, duh...) lol - and my friend was like - do you know that guy?!?! - I’m like - offcourse i know him - he’s Kujotk man!!! KUJOTK!!!......! - That has to be up there amongst some of the better spottages :P
Spotted GTT04D whilst out on a drive... twice actually, once leaving Chatswood and about 30 minutes later heading back home - like the colour and seems to have some power to to it :down:
spotted a silver R32 GTR on friday, plates were TS-75-TS on windsor rd
and on saturday spotted the same black 34 Gt-t twice, once at Norwest fitness first, YIV-177 and again at Rouse Hill shops
Spotted GTT04D whilst out on a drive... twice actually, once leaving Chatswood and about 30 minutes later heading back home - like the colour and seems to have some power to to it :ermm:
Stan,
Yeah was me, spotted you down Rosville Bridge, and then later along Eastern Valley Way
The colour looks so good because it has had a total repsray by a Mercedes Specialist, who did a top notch job.
It has reasonable power, but I've only just started modding it, should have a lot more power soon.
Your ride looked nice also.
Paul
Spotted little red wagon a red stagea on the greater western HWY.plates JAG. somthing
Brad, was it wine red, with JAG69B plates or similar? I've spotted that car a few times, but haven't seen it in ages...
Spotted a gun metal 32 GTR on Herbert St, St Leonards this morning out side the coffee shop just up the road from the forum / train station.
Plates were: BHF-14G
Even at idle the engine sounded tough. Nice car if you're on here mate!
I spotted and parked next to a white R33 GTSt when I went to the shops at Winston Hills earlier. Also, just after I left there I spotted a black R33 GTSt turning right off Powers Road and onto Old Windsor Road in Seven Hills.
