Spotted R34liner again yesturday while i was waiting to catch the 610 into the city (super stealth mode), made him roll down his window while I yelled that i'm Kujo from SAU lol.... everyone else waiting for the bus just looked at me like a wierdo.... meh i am a little crazy, i drive a line....
also few hours later spotted Shane walking in the city, actually he spotted me around the corner from town hall, had a little chat, then we saw a black r34 gtt while we were talking... lol
Hahahahhahahah!!! - that was classic - sitting in traffic and i get this guy who’s sign language-ing me to roll down my window (i was like - umm its electric buddy, duh...) lol - and my friend was like - do you know that guy?!?! - I’m like - offcourse i know him - he’s Kujotk man!!! KUJOTK!!!......! - That has to be up there amongst some of the better spottages :P
Spotted GTT04D whilst out on a drive... twice actually, once leaving Chatswood and about 30 minutes later heading back home - like the colour and seems to have some power to to it :down:
spotted a silver R32 GTR on friday, plates were TS-75-TS on windsor rd
and on saturday spotted the same black 34 Gt-t twice, once at Norwest fitness first, YIV-177 and again at Rouse Hill shops
Spotted GTT04D whilst out on a drive... twice actually, once leaving Chatswood and about 30 minutes later heading back home - like the colour and seems to have some power to to it :ermm:
Stan,
Yeah was me, spotted you down Rosville Bridge, and then later along Eastern Valley Way
The colour looks so good because it has had a total repsray by a Mercedes Specialist, who did a top notch job.
It has reasonable power, but I've only just started modding it, should have a lot more power soon.
Your ride looked nice also.
Paul
Spotted little red wagon a red stagea on the greater western HWY.plates JAG. somthing
Brad, was it wine red, with JAG69B plates or similar? I've spotted that car a few times, but haven't seen it in ages...
Spotted a gun metal 32 GTR on Herbert St, St Leonards this morning out side the coffee shop just up the road from the forum / train station.
Plates were: BHF-14G
Even at idle the engine sounded tough. Nice car if you're on here mate!
I spotted and parked next to a white R33 GTSt when I went to the shops at Winston Hills earlier. Also, just after I left there I spotted a black R33 GTSt turning right off Powers Road and onto Old Windsor Road in Seven Hills.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
