spotted a white R35 on Windsor road on saturday,
also spotted various skylines including a black R34 GT-t yesterday on windsor road, and a silver V35 with a Corrective Services officer driving it :D
Spotted my parked Zed being hit and run side swiped by a cab today.
Yep- that car is truly cursed :laugh:
look in wastelands, there are more people that are unhappy with the way taxis drive with photo proof, you should go in there and confirm to them what happend to you....
hope the damage isnt too bad
cheers :P
actually the damage is decent - definitely no way they could have not felt the hit!
Spotted white 34 yesterday Arvo PL?4ZN had a chat at lights St Marys nice bloke.
Spotted silver 33 m4 city bound around 1:30 today FST 666 if i remember, sat behind me for 30 seconds then took off into the distance.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
