Yesterday I spotted a silver V35 four-door somewhere in my travels around Castle Hill, Baulkham Hills and Glenhaven.
Today, about half an hour ago, I spotted a dark blue s2 R33 in Toongabbie today, going past the set of lights where the overhead railway bridge is. It had some black six-spoke wheels on it, but I was too tired to take note of what kind they were - maybe Buddy Clubs or similar.
ok so i just spotted a few skylines.
Silver R34 GT (i think..guy had red P's so i assume it was only a GT) on Victoria Ave
A Bayside Blue R34 GT-R on Windsor Road, plates were KIM18U
And at the same time a Red R35 on Windsor Road
I spotted a silver V35 this afternoon on Pennant Hills Road in Carlingford at around 5.15pm. It was all stickered-up with the Nismo stripes, "s-tune" logos and Rays/Nismo LM-GT5's, looked hot!
Blue GTR 'KIWI8U', yeah that's my mates car, spotted a silver R35 on Parramatta Rd last night after swannies game, 'BB.ZZZ' or something
saw a Bugatti driving around in Berlin a month ago, i never thought i'd actually see one on the road ever, bloody hell its an ugly car though
Yeah that'd be it.
must of got the M & W confused
Oh, about 5mins after I saw that R35 this afternoon, I also spotted a white R32 GTSt in Pendle Hill with the rear end all smashed up - looks like it had been hit from behind by something with a bull-bar. :)
Ohh and I spotted two Skylines today at Eastgardens carpark.
The first one was a white R33 GTR parked on the ramp going up to the food court.
The second one was another white R33 series two, parked on the bottom level.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
